[Mapserver-dev] 4.0.2 release
Daniel Morissette
dmorissette at dmsolutions.ca
Tue Apr 6 23:40:31 EDT 2004
Steve,
As discussed earlier, I have updated the 4.0.2 HISTORY.TXT and map.h and
tagged the 4.0.2 release in CVS (rel-4-0-2).
You are ready to package the new release and post it to the website
whenever you have a chance.
Thanks
Daniel
P.S. I attached below the list of fixes/changes since 4.0.1
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
Version 4.0.2 (2004-04-06)
- Modified tile4ms to check that all DBFs in tile index have the exact
same set of fields
- Fixed detection of OGRRegisterAll() with GDAL 1.1.9 in configure.
We were looking for libgdal.1.1.so but the name changed to
libgdal.so.x.y.z starting with GDAL 1.1.9
- Fixed the way PROCESSING directives are written in $map->save()
(chameleon bug 154)
- Added layer->dump property in PHP MapScript
- Copied 4.1 mappostgis.c back with changes for pg7.4 support, error
reporting, etc.
