[Mapserver-dev] MapServer CVS - does it support access via SS
H?
Jean-Francois.Doyon at CCRS.NRCan.gc.ca
Wed Apr 7 11:01:57 EDT 2004
Daniel,
Not out of the box, no .... But it's easily done though.
The thing is it runs behind Apache 2 using the WebDAV/DeltaV protocols. Any
and all security you feel like implementing is done via Apache
configuration, including SSL. You just got to make sure the client supports
SSL as well ... I have to guess the supplied command line client can be
compiled with such support ... I use a Windows client myself (TortoiseSVN,
which is a sibbling to TortoiseCVS), that seems to support it. There is a
way to use SSH also if you really want that, but with SSL available, why
would you ? :)
The main documentation for subverion is the book, linked off the home page.
Makes for a very good read, even if you're just trying to evaluate it, as
you discover many of it's features and improvements over CVS that way.
Versioned directories ALONE make it a big improvement !
Hope this helps,
J.F.
-----Original Message-----
From: Daniel Morissette [mailto:dmorissette at dmsolutions.ca]
Sent: Wednesday, April 07, 2004 10:17 AM
To: Jean-Francois.Doyon at CCRS.NRCan.gc.ca
Cc: Mapserver-dev at lists.gis.umn.edu
Subject: Re: [Mapserver-dev] MapServer CVS - does it support access via
SS H?
Jean-Francois.Doyon at CCRS.NRCan.gc.ca wrote:
> Maybe someday someone will look at Subversion ? :)
> (http://subversion.tigris.org)
> I've been using it the past few months and absolutely love it and highly
> recommend it !
I've wanted to check subversion for quite a while, but I still haven't
been able to get to it.
Do you know if subversion supports secure connections out of the box? I
couln't find an answer after a quick scan of the website that you sent.
Daniel
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
