[Mapserver-dev] Building .exes with DLLs on windows
Yewondwossen Assefa
assefa at dmsolutions.ca
Wed Apr 7 18:51:55 EDT 2004
Frank,
I did a couple of tests locally to be able to have mapserver.dll build.
#if defined(_WIN32) && !defined(__CYGWIN__)
# define MS_DLL_EXPORT __declspec(dllexport)
#else
#define MS_DLL_EXPORT
#endif
and most of the protoypes defined in the .h files are declared using the
MS_DLL_EXPORT : MS_DLL_EXPORT int msSaveMap(mapObj *map, char *filename);
The size of the binaries are:
-rwxr-xr-x+ 1 fs None 53297 Apr 7 18:23 legend.exe
-rwxr-xr-x+ 1 fs None 335922 Apr 7 18:23 mapserv.exe
-rwxr-xr-x+ 1 fs None 4137012 Apr 7 18:23 mapserver.dll
-rwxr-xr-x+ 1 fs None 2100568 Apr 7 18:23 mapserver.lib
-rwxr-xr-x+ 1 fs None 473530 Apr 7 18:23 mapserver_i.lib
-rwxr-xr-x+ 1 fs None 53299 Apr 7 18:23 scalebar.exe
-rwxr-xr-x+ 1 fs None 65586 Apr 7 18:23 shp2img.exe
-rwxr-xr-x+ 1 fs None 57394 Apr 7 18:23 shptree.exe
-rwxr-xr-x+ 1 fs None 65586 Apr 7 18:23 sortshp.exe
-rwxr-xr-x+ 1 fs None 69682 Apr 7 18:23 tile4ms.exe
I have tried locally the mapserv.exe and It seems to run fine.
I have also modified the windows makefile to be able to switch between
dll and static modes.
Not sure If I should go ahead and commit the changes. Any thoughts ?
Later,
Frank Warmerdam wrote:
> Yewondwossen Assefa wrote:
>> There should not be any problems on the mapserver side. What "scares"
>> me more is modifing the build for the other dependent libararies to
>> produce dll's and libs that are usable by mapserver. Sometimes It is
>> just a fight to have these libraries build on windows and makefiles,
>> when provided, are not as easy to work as it is in Gdal for example. I
>> will try to gradullay port all the librairies.
> Assefa,
> I don't particularly want to factor all the other dependent libraries out
> as DLLs if they aren't already. For all the ones that are currently
> statically linked into mapserv.exe, they can also be statically linked into
> libmap.dll. Based on this assumption there shouldn't be any need to change
> the dependent libraries, which I agree can be kind of scary.
> Best regards,
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
