[Mapserver-dev] Building .exes with DLLs on windows
Wed Apr 7 18:56:44 EDT 2004
Yewondwossen Assefa wrote:
> Frank,
>  I did a couple of tests locally  to be able to have mapserver.dll build.
> #if defined(_WIN32) && !defined(__CYGWIN__)
> #  define MS_DLL_EXPORT     __declspec(dllexport)
> #else
> #define  MS_DLL_EXPORT
> #endif
>  I have tried locally the mapserv.exe and It seems to run fine.
>  I have also modified the windows makefile to be able to switch between
> dll and static modes.
>  Not sure If I should go ahead and commit the changes. Any thoughts ?
Assefa,
Cool, sounds good.  I think you could commit it, but you might want to clear
it with Daniel as possible release disruption.
Best regards,
