[Mapserver-dev] Fwd: Re: nightly CVS 4/12: shptreevis.c build fails
Steve Lime
steve.lime at dnr.state.mn.us
Tue Apr 13 16:05:21 EDT 2004
More info from William...
>>> William K <woklist at charter.net> 4/13/2004 10:16:27 AM >>>
Sorry, forgot:
Mac OS X 10.3.3. GCC 3.3. Mapserver CVS 2004-4-13 (I said 4-12 since
that's when the mapshape.h and maptree.h were last changed).
On Apr 13, 2004, at 10:10 AM, William K wrote:
> the problem lies in mapshape.h and maptree.h, and causes shapetreevis
> to fail to build. It seems that MS_DLL_EXPORT was added to all the
> function prototypes in these two headers. Yet shapetreevis.c
includes
> those headers directly so MS_DLL_EXPORT never gets defined.
> I don't know the correct way to fix this, but adding the
MS_DLL_EXPORT
> definition lines from map.h to mapshape.h did it for me, and didn't
> break anything else. Maybe shapetreevis.c should include map.h
> instead?
> William Kyngesburye <kyngchaos at charter.net>
> http://webpages.charter.net/kyngchaos/
> [Trillian] What are you supposed to do WITH a maniacally depressed
> robot?
> [Marvin] You think you have problems? What are you supposed to do
if
> you ARE a maniacally depressed robot? No, don't try and answer, I'm
> 50,000 times more intelligent than you and even I don't know the
> answer...
> - HitchHiker's Guide to the Galaxy
"History is an illusion caused by the passage of time, and time is an
illusion caused by the passage of history."
- Hitchhiker's Guide to the Galaxy
