[Mapserver-dev] Fwd: Re: nightly CVS 4/12: shptreevis.c build fails
Yewondwossen Assefa assefa at dmsolutions.ca
Tue Apr 13 16:26:18 EDT 2004
Sorry about that. I never build the shapetreevis on windows so I did not
  see the problem. I am trying it right now with the map.h included in
shapetreevis.c. I will also update the windows makefile to include it in
the build.
Later,
Steve Lime wrote:
> More info from William...
>>>>William K <woklist at charter.net> 4/13/2004 10:16:27 AM >>>
> Sorry, forgot:
> Mac OS X 10.3.3.  GCC 3.3.  Mapserver CVS 2004-4-13 (I said 4-12 since
> that's when the mapshape.h and maptree.h were last changed).
> On Apr 13, 2004, at 10:10 AM, William K wrote:
>>the problem lies in mapshape.h and maptree.h, and causes shapetreevis
>>to fail to build.  It seems that MS_DLL_EXPORT was added to all the
>>function prototypes in these two headers.  Yet shapetreevis.c
> includes
>>those headers directly so MS_DLL_EXPORT never gets defined.
>>I don't know the correct way to fix this, but adding the
> MS_DLL_EXPORT
>>definition lines from map.h to mapshape.h did it for me, and didn't
>>break anything else.  Maybe shapetreevis.c should include map.h
>>instead?
>>William Kyngesburye <kyngchaos at charter.net>
>>http://webpages.charter.net/kyngchaos/
>>[Trillian]  What are you supposed to do WITH a maniacally depressed
>>robot?
>>[Marvin]  You think you have problems?  What are you supposed to do
> if
>>you ARE a maniacally depressed robot?  No, don't try and answer, I'm
>>50,000 times more intelligent than you and even I don't know the
>>answer...
>>- HitchHiker's Guide to the Galaxy
> "History is an illusion caused by the passage of time, and time is an
> illusion caused by the passage of history."
> - Hitchhiker's Guide to the Galaxy
> Mapserver-dev mailing list
> Mapserver-dev at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
