[Mapserver-dev] mapscript layerObj->bounds property or
layerObj->getBounds()method
Steve Lime
steve.lime at dnr.state.mn.us
Fri Apr 16 10:38:09 EDT 2004
There used to be an extent property in the layerObj that users could set
in the map file to
avoid the overhead. A method could leverage that if set.
Steve
>>> Daniel Morissette <dmorissette at dmsolutions.ca> 4/15/2004 2:45:26 PM
AARON KONING wrote:
> Just wondering if there are any plans to include a bounds property
for the layerObj class in mapscript?
> This would help when creating zoomToActiveLayer and zoomToAllLayers
types of functions.
> I realize the bounds of a shapefile can be discovered through the
shapefileObj class, but their is no method available for determining
bounds in other data sources (eg: postgis).
> I suppose one could get around this by parsing the connection and
data properties of the layerObj, but it would be much nicer to have a
bounds property or a getBounds() method to do this.
> It would be great to get this into PHP mapscript for v4.2 :D
If anything is added, it should be a getBounds() or getExtents() method
on the layerObj. It can't be a property since setting this property
all
the time would require opening (and sometimes scanning) the file which
can be slow sometimes.
Unfortunately it's too late for this in 4.2... even though that looks
like a simple addition, it's this kind of "just one more last minute
change" that introduces new issues and makes releases slip for weeks or
months.
I would suggest that you file a enhancement bug about this, and remind
us (via the bug) during the 4.3 release cycle.
Daniel
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
Mapserver-dev mailing list
Mapserver-dev at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
