[Mapserver-dev] mapscript layerObj->bounds property or layerObj->getBounds()
method
Daniel Morissette
dmorissette at dmsolutions.ca
Thu Apr 15 15:45:26 EDT 2004
AARON KONING wrote:
> Just wondering if there are any plans to include a bounds property for the layerObj class in mapscript?
> This would help when creating zoomToActiveLayer and zoomToAllLayers types of functions.
> I realize the bounds of a shapefile can be discovered through the shapefileObj class, but their is no method available for determining bounds in other data sources (eg: postgis).
> I suppose one could get around this by parsing the connection and data properties of the layerObj, but it would be much nicer to have a bounds property or a getBounds() method to do this.
> It would be great to get this into PHP mapscript for v4.2 :D
If anything is added, it should be a getBounds() or getExtents() method
on the layerObj. It can't be a property since setting this property all
the time would require opening (and sometimes scanning) the file which
can be slow sometimes.
Unfortunately it's too late for this in 4.2... even though that looks
like a simple addition, it's this kind of "just one more last minute
change" that introduces new issues and makes releases slip for weeks or
months.
I would suggest that you file a enhancement bug about this, and remind
us (via the bug) during the 4.3 release cycle.
Daniel
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
