[Mapserver-dev] MapFile Java parser
Jean-Henry Berevoescu
bjh at globexplorer.com
Wed Apr 28 06:06:39 EDT 2004
I thought this issue might be of some interest for others too, but I see
it's not the case.
I tried to make the grammar files usable for a Java setup, but without
success. I really see no other option for now, than to do my own
custom parsing. It is not the right solution, but I have no other option
and I need to proceed with my project somehow.
Jean
Jean-Henry Berevoescu wrote:
> Hi,
> I'm need a MapFile Java parser and I'd like to know if there's any way I
> can use the Yacc files from the MapServer's distribution in order to
> generate the parser (with, say, JavaCC or Byacc/Java or any other similar
> tool).
> I can do an independent parser, but I think it will be the best to use
> the same configuration as the one used by MapServer itself, in order
> to achieve maximum compatibility.
> Any help with this issue will be highly apreciated.
> Thanks,
> Jean
