[Mapserver-dev] MapFile Java parser
Sean Gillies
sgillies at frii.com
Wed Apr 28 09:07:35 EDT 2004
Jean,
Instead of writing a custom parser, why not spend the same time to get
the Java MapScript module back in shape? Then you'd have mapfile
parsing capabilities that would stay in synch with MapServer as it
continues to develope.
cheers,
Sean
Jean-Henry Berevoescu wrote:
> I thought this issue might be of some interest for others too, but I see
> it's not the case.
> I tried to make the grammar files usable for a Java setup, but without
> success. I really see no other option for now, than to do my own
> custom parsing. It is not the right solution, but I have no other option
> and I need to proceed with my project somehow.
> Jean
>> Hi,
>> I'm need a MapFile Java parser and I'd like to know if there's any way I
>> can use the Yacc files from the MapServer's distribution in order to
>> generate the parser (with, say, JavaCC or Byacc/Java or any other similar
>> tool).
>> I can do an independent parser, but I think it will be the best to use
>> the same configuration as the one used by MapServer itself, in order
>> to achieve maximum compatibility.
>> Any help with this issue will be highly apreciated.
>> Thanks,
>> Jean
> Mapserver-dev mailing list
> Mapserver-dev at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
