[Mapserver-dev] WMS and LAYERS= vs. STATUS Behaviour
Daniel Morissette
dmorissette at dmsolutions.ca
Wed Apr 28 16:09:15 EDT 2004
Paul Ramsey wrote:
> The issue for WMS client interfaces is that the DEFAULT layers show up
> in the Capabilities file, and there is no indication that these layers
> are "special" in any way. The interface thinks you can turn them on or
> off, so it will give the user buttons to do so. Buttons that will not
> work. If the DEFAULT layers are considered "backdrop" information, not
> an alterable layer, maybe they should not be in the capabilities?
Yeah, I've thought of that before too, but I wasn't sure what was best
between showing them or not. If everybody agrees with hiding the DEFAULT
layers in capabilities then we could make the change in 4.3 (after
creating a bug about this).
Daniel
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
