[Mapserver-dev] WMS and LAYERS= vs. STATUS Behaviour
Bart van den Eijnden
bartvde at xs4all.nl
Wed Apr 28 16:17:52 EDT 2004
I think users of Mapserver should be discouraged to use STATUS DEFAULT in
combination with the WMS interface. The best way to discourage them is to
provide a warning in the capabilities XML in my opinion.
Best regards,
Bart
On Wed, 28 Apr 2004 16:09:15 -0400, Daniel Morissette
<dmorissette at dmsolutions.ca> wrote:
> Paul Ramsey wrote:
>> The issue for WMS client interfaces is that the DEFAULT layers show up
>> in the Capabilities file, and there is no indication that these layers
>> are "special" in any way. The interface thinks you can turn them on or
>> off, so it will give the user buttons to do so. Buttons that will not
>> work. If the DEFAULT layers are considered "backdrop" information, not
>> an alterable layer, maybe they should not be in the capabilities?
> Yeah, I've thought of that before too, but I wasn't sure what was best
> between showing them or not. If everybody agrees with hiding the DEFAULT
> layers in capabilities then we could make the change in 4.3 (after
> creating a bug about this).
> Daniel
