[Mapserver-dev] QUERY_STRING command line parameter
Frank Rittinger
gis at schnegg.net
Mon Aug 2 11:27:36 EDT 2004
Hello
On Monday 02 August 2004 17:04, Daniel Morissette wrote:
> Frank Rittinger wrote:
> > Hello Daniel,
> > On Monday 02 August 2004 15:17, Daniel Morissette wrote:
> >>There was definitely no intention to disable the QUERY_STRING
> >>command-line parameter. I can't test on Windows, but it still works for
> >>me with 4.2.2 on Linux. How did you test that? Did you put double quotes
> >>around the "QUERY_STRING=..." value?
> > Until now, I was useing mapserver 4.0 in the form:
> > mapserv QUERY_STRING="map=foo.map"
> > With mapserver 4.2.0 (that's the one on the mapserver website) I get the
> > message that mapserver can only be used as a CGI script. Putting quotes
> > around the QUERY_STRING parameter doesn't change the error.
> Can you please try with the 4.2.1 binary on the maptools.org site and if
> it has the same problem then please file a bug:
> http://maptools.org/php_mapscript/index.phtml?page=downloads.html
That one works as expected.
Thanks, Frank
