[Mapserver-dev] QUERY_STRING command line parameter
Daniel Morissette
dmorissette at dmsolutions.ca
Mon Aug 2 11:39:07 EDT 2004
Frank Rittinger wrote:
> Hello
>>>Hello Daniel,
>>>On Monday 02 August 2004 15:17, Daniel Morissette wrote:
>>>>There was definitely no intention to disable the QUERY_STRING
>>>>command-line parameter. I can't test on Windows, but it still works for
>>>>me with 4.2.2 on Linux. How did you test that? Did you put double quotes
>>>>around the "QUERY_STRING=..." value?
>>>Until now, I was useing mapserver 4.0 in the form:
>>>mapserv QUERY_STRING="map=foo.map"
>>>With mapserver 4.2.0 (that's the one on the mapserver website) I get the
>>>message that mapserver can only be used as a CGI script. Putting quotes
>>>around the QUERY_STRING parameter doesn't change the error.
>>Can you please try with the 4.2.1 binary on the maptools.org site and if
>>it has the same problem then please file a bug:
>>http://maptools.org/php_mapscript/index.phtml?page=downloads.html
> That one works as expected.
I still wonder why the binaries on the MapServer website didn't work.
I'll CC Pericles on this (he prepares those binaries), perhaps he has an
idea...
Daniel
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
