[Mapserver-dev] Label rotation...
Stephen Woodbridge
woodbri at swoodbridge.com
Wed Aug 4 10:23:36 EDT 2004
We could add an addition option to CW, CCW, COMPASS where COMPASS would
be zero north and CW.
Sorry, I meant CW not CC in my earlier post, but I guess you figured
that out ;)
-Steve
Paul Ramsey wrote:
> Yes, I always considered the label behavior correct, because here in BC
> our toponymy comes with CCW label angles, so applying them directly gave
> me the "correct" looking results. If you invert the behavior then I have
> to negate all my input values before drawing :)
> Unfortunately there is no standard here, people will definately have
> angles of both sorts. (And different start points for measurement too...
> start at north, or start at the positive X axis?)
> P.
> Stephen Woodbridge wrote:
>> Steve Lime wrote:
>>> Just ran into an issue with GD. I probably knew about it but never
>>> really considered it a problem until working on a specific issue
>>> recently. Anyway, GD interprets angles in a counter-clockwise fashion.
>>> So, if you take the letter 'A' and rotate it 90 degrees it points west
>>> instead of east. That's counter intuitive if you're used to compass
>> But exactly what is expected if you are used to vector algebra.
>>> bearings or if you're using labels for "pointing". The fix, for labels
>>> at least, is to simply negate the angle before passing to GD. What do
>>> folks think?
>> What angles are we talking about? Would this change mean that it would
>> change the sense of angle for all existing mapfiles? What happens to
>> people that have angles in their attribute fields?
>>> Note the docs are do not specify a rotation direction...
>> What about adding an optional CC and CCW argument to angles in the
>> mapfile with the default being the CCW like it is today. For example:
>> ANGLE 90
>> ANGLE 90 CC
>> ANGLE 90 CCW
>> or better because it would work with LABELANGLEITEM
>> ANGLE 90
>> ANGLE CC 90
>> ANGLE CCW 90
>> ANGLE CC
>> ANGLE CCW
>> Where the last two would be used anywhere a _____ANGLEITEM field is
>> specific.
>> or also add CC and CCW as trailing optional fields to _____ANGLEITEM
>> like:
>> LABELANGLEITEM "myangles" [CC|CCW]
>> -Steve W.
>> Mapserver-dev mailing list
>> Mapserver-dev at lists.gis.umn.edu
>> http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
