[Mapserver-dev] Label rotation...
Daniel Morissette dmorissette at dmsolutions.ca
Wed Aug 4 10:35:51 EDT 2004
Paul Ramsey wrote:
> Yes, I always considered the label behavior correct, because here in BC
> our toponymy comes with CCW label angles, so applying them directly gave
> me the "correct" looking results. If you invert the behavior then I have
> to negate all my input values before drawing :)
I've always seen angles specified CCW everywhere (that's not specific to
GIS or compass, that's the way it is everywhere in trigonometry,
engineering, physics, etc) so I think we should go with that. I never
checked what MapServer used, but I always assumed it was CCW. If GD uses
CW then it is the exception.
> Unfortunately there is no standard here, people will definately have
> angles of both sorts. (And different start points for measurement too...
> start at north, or start at the positive X axis?)
If you are just rotating an object, as long as you know what the anchor
point for the rotation is, you don't need an absolute reference for the
angle: rotating a symbol 45 degrees CCW is the same whether your start
at the North or the positive X axis.
Daniel
  DM Solutions Group              http://www.dmsolutions.ca/
