[Mapserver-dev] MapOracleSpatial
Fernando S.
simon at inf.univali.br
Tue Aug 17 09:17:09 EDT 2004
This is a multi-part message in MIME format.
--------------050408040306010804010209
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
Content-Transfer-Encoding: 8bit
My name is Fernando Simon and I work for G10 (Laboratório de
Computação Aplicada - Brazil). I am continuing the development of the
MapOracleSpatial source code, at this moment the
msOracleSpatialLayerGetItems function and its complements.
I'm with some problems, I'll try to explain them:
When the fetched rows are equal to zero, I get a weird message after
the results, like this one below:
/"Content-type: text/html" /
And in the source it's like this:
</table>Content-type: text/html
<HTML>
<HEAD><TITLE>MapServer Message</TITLE></HEAD>
<!-- MapServer version 4.2.2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
OUTPUT=WBMP OUTPUT=PDF SUPPORTS=PROJ SUPPORTS=FREETYPE
SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
SUPPORTS=WFS_CLIENT INPUT=TIFF INPUT=EPPL7 INPUT=ORACLESPATIAL
INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE -->
<BODY BGCOLOR="#FFFFFF">
</BODY></HTML>
I followed the code of the mappostgis as example. I followed the same
steps, the else of "if ( 0 < PQntuples(query_result) )", but I still
got this message.
So, what's wrong, am I forgetting any step, anything? What do I need
to do after rows fetched (equal zero), any more functions?
(msOracleSpatialLayerFreeItemInfo?)
Another question is how to use, or what sets the record attribute in
msOracleSpatialLayerGetShape function? If I use the row_num (layerinfo)
will I have the same effect?
Thank's.
Fernando Simon
Content-Type: text/html; charset=us-ascii
Content-Transfer-Encoding: 7bit
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<meta content="text/html;charset=ISO-8859-1" http-equiv="Content-Type">
<title></title>
</head>
<body bgcolor="#ffffff" text="#000000">
Hi,<br>
msOracleSpatialLayerGetItems function and its complements.<br>
<br>
I'm with some problems, I'll try to explain them:<br>
<br>
after the results, like this one below:<br>
<br>
<i>"Content-type: text/html" </i><br>
<br>
And in the source it's like this:<br>
<br>
</<span class="end-tag">table</span>>Content-type: text/html<br>
<<span class="start-tag">HTML</span>><br>
<<span class="start-tag">HEAD</span>><<span
class="start-tag">TITLE</span>>MapServer Message</<span
class="end-tag">TITLE</span>></<span class="end-tag">HEAD</span>><br>
<span class="comment"> <!-- MapServer version 4.2.2 OUTPUT=GIF
OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=PDF SUPPORTS=PROJ
SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT INPUT=TIFF INPUT=EPPL7
INPUT=ORACLESPATIAL INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE --></span><br>
<<span class="start-tag">BODY</span><span class="attribute-name">
BGCOLOR</span>=<span class="attribute-value">"#FFFFFF"</span>><br>
</<span class="end-tag">BODY</span>></<span class="end-tag">HTML</span>><br>
<br>
same steps, the else of "if ( 0 < PQntuples(query_result) )", but I
still got this message. <br>
<br>
need to do after rows fetched (equal zero), any more functions?
(msOracleSpatialLayerFreeItemInfo?)<br>
<br>
in msOracleSpatialLayerGetShape function? If I use the row_num
(layerinfo) will I have the same effect?<br>
<br>
Thank's.<br>
<br>
<br>
Fernando Simon<br>
</body>
</html>
--------------050408040306010804010209--
