[Mapserver-dev] help
jacques
jacques.gariepy at dvp.ca
Tue Aug 24 10:07:03 EDT 2004
This is a multi-part message in MIME format.
------=_NextPart_000_000D_01C489C2.1ABE33F0
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Help !
=20
I will explain a little more my request on the webserver !
I have in this moment a system wms (webserver) and this under
ASP/javascript technology. I use tools of the kind zoom (+/-), panning,
etc.
=20
I seek a means to add a tool, which will make it possible to make the
creation of a dynamic rectangle (draw by the user)=20
=20
and when the rectangle is to create, I will like to be able to withdraw
the co-ordinates ground of this rectangle (x1, x2, y1 and y2).
=20
=20
=20
=20
P.s. For example, go has this bond http://www.dvp-gs.ca/WMS and then not
to change not the information user and password. You will be able to
thus see what I have to create=20
=20
for the moment (thank you not to put this in the newsletter if possible,
because use commercial) !
=20
=20
Jacques Gari=E9py
Programmeur Internet
=20
DVP G=E9omatic Systems Inc.
49 du Bel-Air, suite 203
L=E9vis, Qu=E9bec, Canada, G6V 6K9
=20
CAN/USA 1-800-363-9513
=20
come see us: <http://www.dvp-gs.com/> http://www.dvp-gs.com
=20
Content-Type: text/html;
<html xmlns:o=3D"urn:schemas-microsoft-com:office:office" =
xmlns:w=3D"urn:schemas-microsoft-com:office:word" =
xmlns=3D"http://www.w3.org/TR/REC-html40">
<head>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Diso-8859-1">
<meta name=3DProgId content=3DWord.Document>
<meta name=3DGenerator content=3D"Microsoft Word 10">
<meta name=3DOriginator content=3D"Microsoft Word 10">
<link rel=3DFile-List href=3D"cid:filelist.xml at 01C489C2.1A363F40">
<!--[if gte mso 9]><xml>
<o:OfficeDocumentSettings>
<o:DoNotRelyOnCSS/>
</o:OfficeDocumentSettings>
</xml><![endif]--><!--[if gte mso 9]><xml>
<w:WordDocument>
<w:SpellingState>Clean</w:SpellingState>
<w:GrammarState>Clean</w:GrammarState>
<w:DocumentKind>DocumentEmail</w:DocumentKind>
<w:EnvelopeVis/>
<w:Compatibility>
<w:BreakWrappedTables/>
<w:SnapToGridInCell/>
<w:WrapTextWithPunct/>
<w:UseAsianBreakRules/>
</w:Compatibility>
<w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
</w:WordDocument>
</xml><![endif]-->
<style>
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{mso-style-parent:"";
margin:0cm;
margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:12.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:"Times New Roman";}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;
text-underline:single;}
a:visited, span.MsoHyperlinkFollowed
{color:purple;
span.StyleCourrierlectronique17
{mso-style-type:personal-compose;
mso-style-noshow:yes;
mso-ansi-font-size:10.0pt;
mso-bidi-font-size:10.0pt;
font-family:Arial;
mso-ascii-font-family:Arial;
mso-hansi-font-family:Arial;
mso-bidi-font-family:Arial;
color:windowtext;}
span.SpellE
{mso-style-name:"";
mso-spl-e:yes;}
span.GramE
{mso-style-name:"";
mso-gram-e:yes;}
@page Section1
{size:612.0pt 792.0pt;
margin:72.0pt 90.0pt 72.0pt 90.0pt;
mso-header-margin:35.4pt;
mso-footer-margin:35.4pt;
mso-paper-source:0;}
div.Section1
{page:Section1;}
</style>
<!--[if gte mso 10]>
<style>
/* Style Definitions */=20
table.MsoNormalTable
{mso-style-name:"Tableau Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
font-size:10.0pt;
</style>
<![endif]-->
</head>
<body lang=3DEN-US link=3Dblue vlink=3Dpurple =
style=3D'tab-interval:36.0pt'>
<div class=3DSection1>
<p class=3DMsoNormal><span class=3DGramE><font size=3D1 =
face=3DArial><span
style=3D'font-size:9.0pt;font-family:Arial'>Help =
!</span></font></span><font
size=3D1 face=3DArial><span =
style=3D'font-size:9.0pt;font-family:Arial'><o:p></o:p></span></font></p>=
<p class=3DMsoNormal><font size=3D2 color=3Dnavy face=3DArial><span =
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'><o:p> </o:p></span></font></p>
<p class=3DMsoNormal><font size=3D1 face=3DArial><span =
font-family:Arial'>I will explain a little more my request on the <span
class=3DSpellE><span class=3DGramE>webserver</span></span><span =
class=3DGramE> !</span><o:p></o:p></span></font></p>
<p class=3DMsoNormal style=3D'mso-margin-top-alt:12.0pt'><font size=3D1 =
face=3DArial><span
style=3D'font-size:9.0pt;font-family:Arial'>I have in this moment a =
system <span
class=3DSpellE>wms</span> (<span class=3DSpellE>webserver</span>) and =
this under
ASP/<span class=3DSpellE>javascript</span> technology. I use tools of =
the kind
zoom (+/-), panning, etc.<o:p></o:p></span></font></p>
font-family:Arial'><o:p> </o:p></span></font></p>
font-family:Arial'>I seek a means to add a tool, which will make it =
possible to
make the creation of a dynamic rectangle (draw by the user) =
face=3DArial><span
style=3D'font-size:9.0pt;font-family:Arial'>and</span></font></span><font=
size=3D1
face=3DArial><span style=3D'font-size:9.0pt;font-family:Arial'> when the =
rectangle
is to create, I will like to be able to withdraw the co-ordinates ground =
of
this rectangle (x1, x2, y1 and y2).</span></font><font size=3D2 =
color=3Dnavy
style=3D'font-size:10.0pt;font-family:Arial;color:navy'><o:p></o:p></span=
></font></p>
style=3D'font-size:
font-family:Arial'>P.s. For example, go has this bond <a
href=3D"http://www.dvp-gs.ca/WMS">http://www.dvp-gs.ca/WMS</a> and then =
not to
change not the information user and password. You will be able <span
class=3DGramE>to thus see</span> what I have to create =
face=3DArial><span
style=3D'font-size:9.0pt;font-family:Arial'>for</span></font></span><font=
size=3D1
face=3DArial><span style=3D'font-size:9.0pt;font-family:Arial'> the =
moment (thank
you not to put this in the newsletter if possible, because use =
commercial) !<o:p></o:p></span></font></p>
<p class=3DMsoNormal><font size=3D2 face=3DArial><span =
<div>
<p class=3DMsoNormal><strong><b><font size=3D2 face=3DArial><span =
lang=3DFR-CA
style=3D'font-size:10.0pt;font-family:Arial;mso-ansi-language:FR-CA;mso-n=
o-proof:
yes'>Jacques Gari=E9py</span></font></b></strong><span lang=3DFR-CA
style=3D'mso-ansi-language:FR-CA;mso-no-proof:yes'><o:p></o:p></span></p>=
</div>
<div>
<p class=3DMsoNormal><font size=3D2 face=3DArial><span lang=3DFR-CA =
style=3D'font-size:
10.0pt;font-family:Arial;mso-ansi-language:FR-CA;mso-no-proof:yes'>Progra=
mmeur
Internet</span></font><span lang=3DFR-CA =
</div>
<div>
<p class=3DMsoNormal><font size=3D3 face=3D"Times New Roman"><span =
lang=3DFR-CA
style=3D'font-size:12.0pt;mso-ansi-language:FR-CA;mso-no-proof:yes'> =
;<o:p></o:p></span></font></p>
</div>
<div>
<p class=3DMsoNormal><font size=3D1 face=3DArial><span lang=3DFR-CA =
style=3D'font-size:
7.5pt;font-family:Arial;mso-ansi-language:FR-CA;mso-no-proof:yes'>DVP =
G=E9omatic
Systems Inc.</span></font><span lang=3DFR-CA =
</div>
<div>
style=3D'font-size:
7.5pt;font-family:Arial;mso-ansi-language:FR-CA;mso-no-proof:yes'>49 du
Bel-Air, suite 203</span></font><span lang=3DFR-CA =
</div>
<div>
style=3D'font-size:
7.5pt;font-family:Arial;mso-ansi-language:FR-CA;mso-no-proof:yes'>L=E9vis=
, Qu=E9bec,
Canada, G6V 6K9</span></font><span lang=3DFR-CA =
</div>
<div>
lang=3DFR-CA
</div>
<div>
style=3D'font-size:7.5pt;
font-family:Arial;mso-no-proof:yes'>CAN/USA =
1-800-363-9513</span></font><span
style=3D'mso-no-proof:yes'><o:p></o:p></span></p>
</div>
<div>
style=3D'font-size:
12.0pt;mso-no-proof:yes'> <o:p></o:p></span></font></p>
</div>
<div>
font-family:Arial;mso-no-proof:yes'>come see us: </span></font><span
style=3D'mso-no-proof:yes'><a href=3D"http://www.dvp-gs.com/"><font =
size=3D1
style=3D'font-size:7.5pt;font-family:Arial'>http://www.dvp-gs.com</span><=
/font></a></span><o:p></o:p></p>
</div>
style=3D'font-size:
12.0pt'><o:p> </o:p></span></font></p>
</div>
</body>
</html>
------=_NextPart_000_000D_01C489C2.1ABE33F0--
