[Mapserver-dev] help
Arnulf Christl
arnulf.christl at ccgis.de
Tue Aug 24 12:53:33 EDT 2004
I think maybe you have ended up in the wrong list. This list is beeing
used by people who do internal development on the UMN MapServer engine.
Your problem rather looks like a problem where MapServer users can help.
Try this list, which also has a lot more traffic:
MAPSERVER-USERS at LISTS.UMN.EDU
Cheers, Anrulf.
jacques wrote:
>Help !
>I will explain a little more my request on the webserver !
>I have in this moment a system wms (webserver) and this under
>ASP/javascript technology. I use tools of the kind zoom (+/-), panning,
>etc.
>I seek a means to add a tool, which will make it possible to make the
>creation of a dynamic rectangle (draw by the user)
>and when the rectangle is to create, I will like to be able to withdraw
>the co-ordinates ground of this rectangle (x1, x2, y1 and y2).
>P.s. For example, go has this bond http://www.dvp-gs.ca/WMS and then not
>to change not the information user and password. You will be able to
>thus see what I have to create
>for the moment (thank you not to put this in the newsletter if possible,
>because use commercial) !
>Jacques Gariépy
>Programmeur Internet
>DVP Géomatic Systems Inc.
>49 du Bel-Air, suite 203
>Lévis, Québec, Canada, G6V 6K9
>CAN/USA 1-800-363-9513
>come see us: <http://www.dvp-gs.com/> http://www.dvp-gs.com
CCGIS Christl & Stamm GbR
http://www.ccgis.de
http://www.mapbender.org
Service: +49 (0)228 90826 0
Direct: +49 (0)228 90826 23
Fax: +49 (0)228 90826 11
Siemensstraße 8
53121 Bonn
GERMANY
