PHP's bundled regex/*.o
Daniel Morissette
dmorissette at DMSOLUTIONS.CA
Tue Dec 14 17:08:31 EST 2004
Daniel Morissette wrote:
> Segfault on fopen()? That's the first time I hear of that one. I could
> imagine the possibility of a crash if you try to use your
> php_mapscript.so built with php's regex/*.o with a php4 cgi that was
> built with the system regex, but you say that you have the exact same
> problem with shp2img so that can explain the shp2img crash.
Of course here I meant "...you have the exact same problem with shp2img
so that _CANNOT_ explain the shp2img crash."
Daniel
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
