[Mapserver-dev] Problem building from CVS...
Frank Warmerdam
warmerdam at pobox.com
Thu Feb 12 15:27:27 EST 2004
Steve Lime wrote:
> And more, the section to set the location of libjpeg is no longer run
> before the gd code in configure.in. Looks like the GD test can never
> succeed if GD was built with jpeg support.
Steve,
OK, I think I have this fixed. As things are currently, by default I
believe libjpeg will be linked in if available, but -DUSE_JPEG (which
determines if it is used for reading jpeg files in raster rendering) will
not appear if GDAL is enabled. I don't have a gd build statically lnked
against libjpeg so it is hard to be sure I got stuff right.
I would note, I also had to fiddle with the logic that checks on Apache 2.0
for stderr/logging issues. There were a number of problems with it that
resulted in errors at runtime.
I hate configure work!
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
