[Mapserver-dev] Problem building from CVS...
Steve Lime steve.lime at dnr.state.mn.us
Thu Feb 12 00:44:37 EST 2004
And even more, on Linux libjpeg is usually installed as a shared
library, so the compilation of the test program passes there. In my case
libjpeg is a static library and it bombs. So the problem is limited to
folks with gd compiled with static versions of libjpeg- configure won't
work in that case...
>>> "Steve Lime" <steve.lime at dnr.state.mn.us> 02/11/04 11:29 PM >>>
And more, the section to set the location of libjpeg is no longer run
before the gd code in configure.in. Looks like the GD test can never
succeed if GD was built with jpeg support.
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> Steve Lime 02/11/04 11:14 PM >>>
More information. Config.log gives me:
gcc -o conftest -g -O2   conftest.c -lgd  -lfreetype -lpng -lz
-liconv  -lm -lstdc++  >&5
ld: warning prebinding disabled because dependent library:
/usr/local/lib/libgd.
2.dylib is not prebound
ld: Undefined symbols:
_jpeg_CreateCompress
_jpeg_CreateDecompress
_jpeg_destroy
_jpeg_destroy_compress
...and so on...
for some reason libjpeg is not being picked up and included test program
compilation, so the test program fails.
Steve
>>> "Steve Lime" <steve.lime at dnr.state.mn.us> 02/11/04 9:44 PM >>>
Anyone else having trouble building from scratch via the CVS? Granted
I'm on a mac and it seems have somewhat mystical powers from time to
time, but as recently as 1/20 all was well. Issue is that configure is
not finding GD even though it's new enough and in the normal place. The
recent changes in configure.in don't seem like they could be the issue.
Could someone try on their machine (autoconf etc...) and confirm the
problem is limited to me.
Thanks- Steve
Mapserver-dev mailing list
Mapserver-dev at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
