[Mapserver-dev] Problem building from CVS...
Steve Lime steve.lime at dnr.state.mn.us
Thu Feb 12 15:49:57 EST 2004
Thanks for fixing. We could just ditch internal input JPEG support
altogether, same thing for TIFF. I know you've been reluctant but it's a
pain in the rear sometimes having both...
I'll test as soon as I get home.
Steve
>>> Frank Warmerdam <warmerdam at pobox.com> 2/12/2004 2:27:27 PM >>>
Steve Lime wrote:
> And more, the section to set the location of libjpeg is no longer
run
> before the gd code in configure.in. Looks like the GD test can never
> succeed if GD was built with jpeg support.
Steve,
OK, I think I have this fixed.   As things are currently, by default I
believe libjpeg will be linked in if available, but -DUSE_JPEG (which
determines if it is used for reading jpeg files in raster rendering)
will
not appear if GDAL is enabled.  I don't have a gd build statically
lnked
against libjpeg so it is hard to be sure I got stuff right.
I would note, I also had to fiddle with the logic that checks on Apache
2.0
for stderr/logging issues.  There were a number of problems with it
that
resulted in errors at runtime.
I hate configure work!
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
and watch the world go round - Rush    | Geospatial Programmer for
Rent
