[Mapserver-dev] WFS interoperability issues
Rob Atkinson rob at socialchange.net.au
Thu Feb 12 22:41:50 EST 2004
Thanks very much Bart
> I am using a different binary version and the POST request works
> perfectly.
For me it responds with (an improperly formatted) error message:
    "    POST body is short"
possibly because I do not set the Content-length property in the POST.
It works on every other HTTP POST base Web service  implementation I've
seen however. (And no - I really dont want to serialise my XML again
just to see how big it is)
> You can download a CVS binary from 2 February 2004 at:
> http://www.xs4all.nl/~bartvde/mapserv_41.exe
thanks for this.  Seems to behave the same FYI
> With respect to the MAP file parameter, just use it in the URL to
> which you post. E.g. in my test I post to:
> http://myserver/cgi-bin/mapserv.exe?map=/ms4w/apps/general/map/gemeentes.map
To my mind this is rather mixing GET and POST - but I'd be happy to be
proved wrong
it may be more legal to do this
http://myserver/cgi-bin/mapserv.exe/ms4w/apps/general/map/gemeentes.map
