[Mapserver-dev] WFS interoperability issues
Bart van den Eijnden
bartvde at xs4all.nl
Thu Feb 12 16:20:28 EST 2004
Hi Rob,
I am also very interested in this, but I think the functionality is still
under (heavy) development by DM Solutions.
I am using a different binary version and the POST request works perfectly.
You can download a CVS binary from 2 February 2004 at:
http://www.xs4all.nl/~bartvde/mapserv_41.exe
With respect to the MAP file parameter, just use it in the URL to which
you post. E.g. in my test I post to:
http://myserver/cgi-bin/mapserv.exe?map=/ms4w/apps/general/map/gemeentes.map
Hope this answers at least some of your questions.
Best regards,
Bart
On Thu, 12 Feb 2004 13:21:09 +1100, Rob Atkinson <rob at socialchange.net.au>
wrote:
> Hi folk,
> have been doing some interoperability testing on WFS functionality in
> v4.01 and 4.1
> at this stage I have been using precompiled binaries, so these comments
> do refer to 4.1-dev Windoze.
> 4.1 is a big improvement over 4.0 - so much so I'm happy to help get the
> last few glitches ironed out and start using the beast.
> Here are the key issues:
> 1) The capabilities response offers both POST and GET - but only GET
> appears to work. This may be due to the fact I need to specify the
> mapfile and there is no obvious way of doing that in the POST request. I
> have searched documentation, bug lists and archives and not been able to
> find how you intend to address this.
> 2) POST requests are returning non-XML responses - PNG images!
> 3) Features have no formal identifier (in GML 2 the "fid" atttribute) -
> I see this is a reported bug already - but would like to stress its
> importance. It is also important that "fids" can be made persistent -
> they are an object identifier after all. I would suggest that the map
> file syntax be extended to allow the nomination of a field to be mapped
> to this.
> Would appreciate any info on these matters and whether I need to fix -
> would prefer to perform testing if someone else can do it.
> Regards
> Rob Atkinson
> Mapserver-dev mailing list
> Mapserver-dev at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
