[Mapserver-dev] HTTP Post Handling
Fri Feb 13 10:21:02 EST 2004
Rob Atkinson wrote:
> The relevant RFC states that:
> /For compatibility with HTTP/1.0 applications, HTTP/1.1 requests
> containing a message-body MUST include a valid Content-Length header
> field unless the server is known to be HTTP/1.1 compliant. If a request
> contains a message-body and a Content-Length is not given, the server
> SHOULD respond with 400 (bad request) if it cannot determine the length
> of the message, or with 411 (length required) if it wishes to insist on
> receiving a valid Content-Length.
> IMHO, this means that if mapserv is served by a HTTP 1.1 compliant
> server there is no requirement for the client to set the Content-Length
> and thus thus code in cgiutils.c :
>    cl = atoi(getenv("CONTENT_LENGTH"));
>     if(strcmp(request->contenttype, "application/x-www-form-urlencoded")) {
>       request->postrequest = (char *)malloc(sizeof(char)*cl+1);
>       if (fread(request->postrequest, 1, cl, stdin) < cl){
>         printf("Content-type: text/html%c%c",10,10);
>         printf("POST body is short\n");
>         exit(1);
> is at fault. At the very least it should throw a 411 exception, but it
> would be better to make it more robust.
Rob,
There is no excuse for us not to just read the data dynamically if there
is no Content-Length.  I have done this in a number of other web services.
I would suggest you file it as a bug in bugzilla.  If no one else will fix
it then I will, but it would be helpful to have a test case I could easily
use to test it.
Best regards,
