[Mapserver-dev] Example of Structured Text
Sean Gillies
sgillies at frii.com
Wed Feb 18 10:48:58 EST 2004
Hi all,
Here's an example of what Norman was talking about. I've slapped
together a quick and incomplete documentation for the rectObj
shadow class in Structured Text. Here is the source (between the
dashed lines)
class **rectObj**
Attributes
float *minx*, float *miny*, float *maxx*, float *maxy*
Constructor
rectObj([float *minx*, float *miny*, float *maxx*, float
*maxy*])
Returns **rectObj**
Methods
draw(**mapObj** *map*, **layerObj** *layer*, **imageObj**
*img*, int *classindex* [, string *text*])
Draw rectangle into *img* using style defined by the
*classindex* class of *layer*.
toPolygon()
Convert to a polygon, returns **shapeObj**
It's readable, yes? And here's what it could look like rendered into
HTML:
http://dev.zope.org/Members/sgillies/stx_doc_example/document_view
It could also be rendered into DocBook with some XML hacking.
cheers,
Sean
Sean Gillies
sgillies at frii dot com
http://users.frii.com/sgillies
