[Mapserver-dev] Example of Structured Text
Sean Gillies
sgillies at frii.com
Wed Feb 18 11:23:18 EST 2004
On Feb 18, 2004, at 8:48 AM, Sean Gillies wrote:
> Hi all,
> Here's an example of what Norman was talking about. I've slapped
> together a quick and incomplete documentation for the rectObj
> shadow class in Structured Text. Here is the source (between the
> dashed lines)
Ack, forgot that zope dev is moderated. Will take a few minutes for
my doc to be live. Here's a screenshot:
Sorry, Daniel, I forgot that zope dev is moderated. Will take a few
minutes
for my doc to get out. Here's a screenshot:
http://users.frii.com/sgillies/images/stx.jpg
Sean
> class **rectObj**
> Attributes
> float *minx*, float *miny*, float *maxx*, float *maxy*
> Constructor
> rectObj([float *minx*, float *miny*, float *maxx*, float
> *maxy*])
> Returns **rectObj**
> Methods
> draw(**mapObj** *map*, **layerObj** *layer*, **imageObj**
> *img*, int *classindex* [, string *text*])
> Draw rectangle into *img* using style defined by the
> *classindex* class of *layer*.
> toPolygon()
> Convert to a polygon, returns **shapeObj**
> It's readable, yes? And here's what it could look like rendered into
> HTML:
> http://dev.zope.org/Members/sgillies/stx_doc_example/document_view
> It could also be rendered into DocBook with some XML hacking.
> cheers,
> Sean
> Sean Gillies
> sgillies at frii dot com
> Mapserver-dev mailing list
> Mapserver-dev at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
