[Mapserver-dev] Proposal for mapscript documentation using Restructured
text
Daniel Morissette
dmorissette at dmsolutions.ca
Wed Feb 18 18:37:45 EST 2004
Sean Gillies wrote:
> Here is an even better example of what we can do with Restructured text:
> http://users.frii.com/sgillies/examples/mapscript.html
> RST is wiki-like (better than wiki!) and the source is still quite readable
> for those who want a plain text file. There is a link at the bottom of the
> HTML page which will show the plain text RST file.
> I have committed the source to the CVS head under mapscript/doc. If folks
> like what they see and feel that the Restructured text syntax isn't too
> cumbersome, I would be willing to take care of converting the mapscript.txt
> file to HTML for each release.
> This approach to the documentation, IMO, satisfies the major beefs that
> developers have. It's easy to edit and maintain, has readable source,
> and can generate docs with hyperlinks. I'm certain that with a little
> effort
> we can come up with a DocBook writer that will satisfy MDP.
Looks like this would do the trick. Let's see what others think.
Do you have a pointer to the tool to convert to HTML? Is it easy to
install? I think it would be good for developers to be able to test that
the file looks ok before they commit a new version to CVS.
If we move ahead with this then we could start from the
mapscript/php3/README file to produce the first version of the docs
since we have all the classes and methods documented in it. Unless
someone has a better source to start from?
Daniel
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
