[Mapserver-dev] Proposal for mapscript documentation using Restructuredtext
Steve Lime steve.lime at dnr.state.mn.us
Thu Feb 19 01:35:45 EST 2004
I agree with Dan about merging documentation. If we don't want to go
nuts and merge with PHP initially that's cool, but ultimately that
should be the plan. That will help force keeping the variants in sync.
Sean's example is fine as a starting point but I think we'll need a
human(s) to keep the documentation on track an to  deal with language
issues. Lowell Flak probably has the best version (aleit with frames)
outside of the DMS PHP stuff now. Assuming he (and others) are
interested, what about producing a base docbook version automagically
and then turning them loose?
Steve
>>> Daniel Morissette <dmorissette at dmsolutions.ca> 02/18/04 10:54 PM >>>
Sean Gillies wrote:
> Are you talking about merging the SWIG and PHP mapscript
documentation?
>  It might
> be premature since the modules aren't truly merged yet.  There are
> exclusive
> functions in each and differently named functions and classes ... much
> yet to do.
> I do think that new SWIG mapscript documentation will borrow heavily
from
> the PHP readme but should be documentation of the module as it
currently
> stands.
Yes, I was suggesting that we merge the SWIG and PHP docs. I realize
that this merge of the docs may be a bit premature, but since I was the
one who brought up the documentation issue in the first place I couldn't
really just sit back and keep PHP as a separate beast after advocating
against having 4 or 6 separate sets of docs.
Anyway, either way is good for me, as long as we have a mechanism for
developers to maintain SWIG docs. :)  I'm willing to work with you (and
the rest of the group) if you want to merge PHP docs with the SWIG docs
now, but in order to facilitate things we may be better concentrating
only on the SWIG stuff for now as you suggest, and merging with PHP only
down the road once the SWIG stuff is in good shape.
Daniel
  Daniel Morissette               dmorissette at dmsolutions.ca
  DM Solutions Group              http://www.dmsolutions.ca/
Mapserver-dev mailing list
Mapserver-dev at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
