[Mapserver-dev] Proposal for mapscript documentation using Re
structuredtext
Jean-Francois.Doyon at CCRS.NRCan.gc.ca
Thu Feb 19 09:52:27 EST 2004
Gents,
First of all, I'd suggest this conversation be moved to the MDP's list, or
at least Kari be included ?
Also, I just tried to document classes and methods and so on using DocBook,
and had only marginal success. Turns out the stylesheet doesn't yet support
"Python" syntax ... Which is what I was tring to do. It does support Java
and Perl though.
I still feel however that we should stick to MDP set standards ... that's
why they're there. The style sheet could maybe be extended to support what
we need it to ? The additions could even be fed back to maintainer of the
DocBook StyleSheets !
All in all though, Kari is the documentation maintainer, and she really
should be coordinating this effort, no ?
And we have a mailing list for discussing documentation issues as well, so
might as well use it ?
Just a thought :)
J.F.
-----Original Message-----
[mailto:mapserver-dev-admin at lists.gis.umn.edu]On Behalf Of Steve Lime
Sent: Thursday, February 19, 2004 1:36 AM
To: dmorissette at dmsolutions.ca; sgillies at frii.com
Cc: Mapserver-dev at lists.gis.umn.edu
Subject: Re: [Mapserver-dev] Proposal for mapscript documentation using
Restructuredtext
I agree with Dan about merging documentation. If we don't want to go
nuts and merge with PHP initially that's cool, but ultimately that
should be the plan. That will help force keeping the variants in sync.
Sean's example is fine as a starting point but I think we'll need a
human(s) to keep the documentation on track an to deal with language
issues. Lowell Flak probably has the best version (aleit with frames)
outside of the DMS PHP stuff now. Assuming he (and others) are
interested, what about producing a base docbook version automagically
and then turning them loose?
Steve
>>> Daniel Morissette <dmorissette at dmsolutions.ca> 02/18/04 10:54 PM >>>
Sean Gillies wrote:
> Are you talking about merging the SWIG and PHP mapscript
documentation?
> It might
> be premature since the modules aren't truly merged yet. There are
> exclusive
> functions in each and differently named functions and classes ... much
> yet to do.
> I do think that new SWIG mapscript documentation will borrow heavily
from
> the PHP readme but should be documentation of the module as it
currently
> stands.
Yes, I was suggesting that we merge the SWIG and PHP docs. I realize
that this merge of the docs may be a bit premature, but since I was the
one who brought up the documentation issue in the first place I couldn't
really just sit back and keep PHP as a separate beast after advocating
against having 4 or 6 separate sets of docs.
Anyway, either way is good for me, as long as we have a mechanism for
developers to maintain SWIG docs. :) I'm willing to work with you (and
the rest of the group) if you want to merge PHP docs with the SWIG docs
now, but in order to facilitate things we may be better concentrating
only on the SWIG stuff for now as you suggest, and merging with PHP only
down the road once the SWIG stuff is in good shape.
Daniel
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
Mapserver-dev mailing list
http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
