[Mapserver-dev] Question about basic authentication in a WMS connection
Bart van den Eijnden
bartvde at xs4all.nl
Fri Feb 27 15:50:38 EST 2004
Hi Sean,
I use a Windows binary from 02-02-2004 and there it still works.
Is this syntax working for you in e.g. Mozilla Firefox when you do a
GetCapabilities request on the remote WMS?
Best regards,
Bart
On Fri, 27 Feb 2004 13:28:58 -0700, Sean Gillies <sgillies at frii.com> wrote:
> Hi all, I've run into a nasty bug with a WMS client connection. I'm
> digging
> into the code right now, but am hoping that one of the WMS developers
> will
> have some suggestions for me.
> Problem is that with the CVS mapserver a WMS layer with a connection like
> CONNECTION "http://user:passwd@host/servlet?&foo=bar"
> is falling all the way through the logic in msDrawLayer to the point
> where
> we try to draw it using drawEPPL(). Any reasons why this connection
> wouldn't work?
> Here is a layer that works for me
> LAYER
> NAME "aerial"
> TYPE RASTER
> STATUS ON
> CONNECTION "http://terraservice.net/ogcmap.ashx"
> CONNECTIONTYPE WMS
> METADATA
> "wms_srs" "EPSG:4326"
> "wms_name" "DOQ"
> "wms_style" ""
> "wms_server_version" "1.1.1"
> "wms_format" "image/jpeg"
> "wms_connectiontimeout" "60"
> END
> PROJECTION
> "init=EPSG:4326"
> END
> END
> And this layer (service's name has been changed to protect the innocent
> fails
> LAYER
> NAME "aerial"
> TYPE RASTER
> STATUS ON
> CONNECTIONTYPE WMS
> METADATA
> "wms_name" "DOQ"
> "wms_style" ""
> END
> PROJECTION
> "init=EPSG:4326"
> END
> END
> Mapserver-dev mailing list
> Mapserver-dev at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
