[Mapserver-dev] Re: time support
Steve Lime
steve.lime at dnr.state.mn.us
Tue Jan 6 13:00:42 EST 2004
My plan is to allow arbitrary fields to be added to the tileindex, and
then filter
against whatever you need- startdate-enddate, sensor name or whatever.
Sounds
like to meet your needs we'd need to generalize tiles futher by
allowing non-shapefile
tile indexes. I could see moving TILEINDEX into it's own object, almost
a mini-layer.
So you could do something like:
TILEINDEX
DATA ...
CONNECTION ...
FILTER ...
FILTERITEM ...
TILEITEM ...
END
Other ideas?
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> "David W. Graham" <dgraham at i3.com> 1/5/2004 5:18:26 PM >>>
Steve:
Just catching up on the conversation. It is very timely for us at
i-cubed.
:) I am trying to find a way to stream (WMS) a series of tiles that
will be
updated quite often (atleast every 2 weeks) with new versions. All
versions
must be available for streaming.
We are looking at a Postgres (Postgis) solution. But as I look at
this
converstion, it seems that a solution similarly to the one we are
looking at
would probably be quite useful to the temporal discussion.
My solution is simply to add a date field to the tileindex (.i.e there
will
be overlapping polygons with differing date and location attributes).
Then
move the tile index into PostGIS so I can keep the massive flood of
data we
are potentially looking at under control.
It will likely be a mapscript hack.
Dave
________________________________________________
David W. Graham
Director of Application Development
dgraham at i3.com
Voice: +1-970-482-4400
Fax: +1-970-482-4499
Web: www.i3.com
i-cubed
201 Linden, Third Floor
Fort Collins, CO 80524
-----Original Message-----
[mailto:mapserver-dev-admin at lists.gis.umn.edu] On Behalf Of Steve Lime
Sent: Wednesday, December 17, 2003 9:11 AM
To: morissette at dmsolutions.ca
Cc: mapserver-dev at lists.gis.umn.edu
Subject: Re: [Mapserver-dev] Re: time support
I not convinced I'm right though. The more I've thought about it the
more I
like extending TILEINDEX. Franks here today, I'll bounce it off him.
Steve
>>> Daniel Morissette <morissette at dmsolutions.ca> 12/17/2003 9:49:38
AM
Steve Lime wrote:
> A timeindex would not be a shapefile, rather simply a temporal
lookup
> table. An xbase file would do nicely.
You're right. I didn't realize that.
> That
> way date expressions could be used with any data source if a column
> contained ISO8601 formated date/time strings. In that case using a
> timeindex for anything but raster data may not be necessary. Raster
data
> is certainly the task at hand for me.
Actually, some people might have one shapefile per time range (or time
value), so I can see why this TIMEINDEX would be useful to shapefiles
as
well. Imagine an organization with 100 years of daily weather data:
that's too much information to store in a single shapefile if you want
reasonable performance. I guess they would be better using a RDBMS
than
shapefiles for this anyway, but that's an example where TIMEINDEX on
shapefiles could be used.
Daniel
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
Mapserver-dev mailing list
Mapserver-dev at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
