[Mapserver-dev] layer queryByShape and SDE
Howard Butler
hobu at iastate.edu
Thu Jan 15 17:42:26 EST 2004
Dear List,
I am having some problems querying an SDE layer using mapscript and the
layer.queryByShape method. I have two SDE layers, counties, and state, and
I can query for a state and get it returned into a shapeObj without much
trouble. When I try to use that shape to query against the counties layer,
I run into trouble. Both layers have a TEMPLATE defined in the mapfile.
def return_results(amap, statename):
import sys
cnty_layer = amap.getLayerByName("counties")
state_layer = amap.getLayerByName("state")
state_layer.filteritem = 'STATENAME'
qstring = "UPPER(STATENAME) = '%s'" % statename.upper()
qryresult = state_layer.queryByAttributes(amap, 'STATENAME', qstring,
MS_MULTIPLE)
state_layer.open()
resultmember = state_layer.getResult(0)
index = int(resultmember.shapeindex)
myShape = shapeObj(MS_SHAPE_POLYGON)
state_layer.getShape(myShape,-1,index)
statename= myShape.getValue(1) #the field named "STATENAME"
sys.stderr.write('Statename %s\n'%statename) #prints correct name
cnty_result = cnty_layer.queryByShape(amap, myShape) # <-- crashes here
The mapscript is in Python. Running it through gdb shows that it is
crashing here:
msAddLine (p=0xbffff180, new_line=0xbffff028) at mapprimitive.c:126
126 extended_line[c]= p->line[c];
At the moment, I am stumped. Any ideas, pointers, or requests for more
information would be greatly appreciated.
Thanks
Howard
