[Mapserver-dev] labels generated upside down
woodbri at swoodbridge.com
Sun Jan 25 18:07:01 EST 2004
So, I take it no one else has seen this problem.
I could NOT find anything in bugzilla.
And I have not been able to narrow down an example that is small
enough to submit to bugzilla because removing data changes the
labelling enough to cause the problem labels to shift around and
removes the problem but it is easily reproduced on our servers ....
-Steve
On 14 Jan 2004 at 16:20, woodbri at swoodbridge.com wrote:
> Hi all,
> Labelling streets I get occasional labels the are placed upside down.
> Using ANGLE AUTO
> This happens with two different builds using similar but slightly
> different versions of libraries. Is this a know bug? I could find it
> in bugzilla.
> Linux build
> MS 4.0
> later/latest copies of GD 2
> later/latest copies of freetype
> GDAL, proj, etc
> -Steve W.
> Mapserver-dev mailing list
> Mapserver-dev at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
