[Mapserver-dev] cpl utility functions
Yewondwossen Assefa
assefa at dmsolutions.ca
Thu Jul 22 10:04:59 EDT 2004
Frank Warmerdam wrote:
> Daniel Morissette wrote:
>> Yewondwossen Assefa wrote:
>>> I need to use some utility function that are available in gdal
>>> cpl_xxx library. (In this specific case it is functions like
>>> CPLGetBasename). At the same time, It seems a bit odd to add a
>>> dependency to GDAL/OGR just to have access to a couple of functions.
>>> (in this case It is the swf module and It should normally not need
>>> gdal to work).
>>> What is the general guidline for such a case ? Do we need to add
>>> the dependency ? Do I copy the functions inside mapserver utility
>>> files ?
>> In the past we've always tried to avoid using CPL in MapServer source
>> (except in code that relies on GDAL/OGR already). What I've done when
>> I ran into those cases was either find another way to do the same
>> thing, or implement an equivalent function (or rename and copy the CPL
>> function) in mapstring.c or where it fits best.
>> I'm not sure it's a good idea to create a dependency on CPL, but OTOH
>> it provides several very useful utility functions that we often end up
>> having to replicate... let's see what others think.
> Assefa / Daniel,
> My take is similar to Daniel's. I think that for small utility functions
> from CPL, you should just replicate them into mapserver. I would
> like to suggest though that:
> o We make a map_cpl.c file with morphed code.
> o We exactly change CPL to "ms" but otherwise leave the function the
> same externally so it will be easy to use and recognise for folks who
> know CPL a bit. So CPLGetBasename() would become msGetBasename().
> o When you copy over the implementation you will of course need to
> modify the code internally to use mapserver services for memory
> allocation and various macros. Most are pretty simple.
If there is no objection, I will add the functions I need into a new
file map_cpl.c.
> I was going to suggest that you dump them into maputil.c, but decided
> not to.
> Boy is that file a hodge-podge of stuff. Why are there lots of functions
> in there not starting with ms, like getMeasureUsingPoint()?
I am going to rename also the function getMeasureUsingPoint. It was done
few years back and I did not consider at that time the masperverver
naming convention.
Thanks.
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
