[Mapserver-dev] cpl utility functions
Daniel Morissette dmorissette at dmsolutions.ca
Thu Jul 22 10:15:19 EDT 2004
Yewondwossen Assefa wrote:
>> My take is similar to Daniel's.  I think that for small utility functions
>> from CPL, you should just replicate them into mapserver.  I would
>> like to suggest though that:
>>  o We make a map_cpl.c file with morphed code.
>>  o We exactly change CPL to "ms" but otherwise leave the function the
>>    same externally so it will be easy to use and recognise for folks who
>>    know CPL a bit. So CPLGetBasename() would become msGetBasename().
>>  o When you copy over the implementation you will of course need to
>>    modify the code internally to use mapserver services for memory
>>    allocation and various macros.  Most are pretty simple.
>  If there is no objection, I will add the functions I need into a new
> file map_cpl.c.
I like Frank's suggestions as well... but perhaps call the file mapcpl.c
since there are no filenames with underscores (i.e. map_something.c) in
the MapServer source.
Daniel
  DM Solutions Group              http://www.dmsolutions.ca/
