[Mapserver-dev] Compile Mapserver 4.2.1 on window2000 ? (GD's
question)
Yewondwossen Assefa
assefa at dmsolutions.ca
Fri Jul 23 12:07:58 EDT 2004
Hi There,
I also tried to use the binaries from boutell to build with mapserver.
Athough the build works ok, I get a crash when saving a gd image into a
file (gdImagePng(img, stream)). I really don't know why and there is no
way to debug this. Too bad because It would have been really nice to
not have to build gd on windows.
I guess you should try to build gd using the source code (which is what
I think every one is doing). You can contact me off the list if you need
a msvc makefile.
Later,
lzp lzp wrote:
> hello,my friend
> I compiled mapserver 4.2.1 on my win2000 pc,but it seems error at
> running at tha apache2 server.
> I will tell you how I compile it,so anybody can tell me any wrong
> step?
> My Server: Windows2000 advance Server (with sp4)
> Visual Studio 6 (with sp5)
> (1) step 1: I download gdwin32.zip from
> http://www.boutell.com/gd/http/gdwin32.zip. And unzip it to
> c:\projects\gdwin32
> So I can run c:\projects\gdwin32\makemsvcimport.bat,then get the file
> bgd.exp and bgd.lib
> Question 1: Which gd release edition should I use:Gdwin32.zip or
> gd-2.0.28.zip?If I should use source code ,how could I compile it on
> windows?
> Question 2:gd.lib?or bgd.lib?
> As I say before,If run makemsvcimport.bat directly ,I will get
> bgd.exp and bgd.lib. So I must edit mapserver¡¯s nmake.opt in line 369:
> GD_LIB= $(GD_DIR)/bgd.lib \
> Is it right???
> And I only get the bgd.dll from the gdwin32.zip, Should I
> rename it from bgd.dll to gd.dll? Is It necessary?
> OK, today is only step 1 with 2 question
> ThanksJ)
> Denzel
> *Do You Yahoo!?*
> ÃÀÅ®Ã÷ÐÇÓ¦Óо¡ÓУ¬"Ò»ËÑ"ËѱéÃÀͼ¡¢ÑÞͼºÍ¿áͼ <http://image.yisou.com>
> 100Õ×ÓÊÏä¹»²»¹»Óã¿ÑÅ»¢µçÓÊ×ÔÖúÀ©ÈÝ£¡
> <http://cn.rd.yahoo.com/mail_cn/tag/100m/*http://cn.promo.yahoo.com/minisite/100m/>
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
