[Mapserver-dev] 4.2.2 Release
Sean Gillies sgillies at frii.com
Tue Jul 27 09:33:45 EDT 2004
On Jul 27, 2004, at 4:21 AM, Markus Spring wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Steve Lime wrote:
> | I backported my changes to the templating code, and Howard did so as
> | well with some SDE code. It folks could test things on a few
> platforms
> | (I've tried MacOS and Linux/Redhat) we should be ready (after Sean's
> | tests) to move forward and release. Thoughts?
> I'd like to test it, however CVS access is only documented for head
> revision
> which is 4.3-to-be, but not 4.2.2
> Kind regards
> markus
Markus,
cvs checkout -r branch-4-2 mapserver
Make sure to do this away from the checkout of the CVS HEAD.
cheers,
Sean
Sean Gillies
sgillies at frii dot com
http://users.frii.com/sgillies
