[Mapserver-dev] 4.2.2 Release
Tue Jul 27 09:48:52 EDT 2004
Steve Lime wrote:
> I backported my changes to the templating code, and Howard did so as
> well with some SDE code. It folks could test things on a few platforms
> (I've tried MacOS and Linux/Redhat) we should be ready (after Sean's
> tests) to move forward and release. Thoughts?
Steve,
I have run the msautotest suite and only four tests failed.  Investigation
showed those were all expected results from fixes in the 4.2 series or
acceptable variations.  So as far as I am concerned 4.2.2 is ready to go.
Best regards,
