[Mapserver-dev] 4.2.2 Release
Stephen Clark
stephen.clark at focus.ca
Tue Jul 27 13:25:39 EDT 2004
Has the bug been fixed with adding layers dynamically in 4.2.2?
Stephen
----- Original Message -----
To: "Steve Lime" <steve.lime at dnr.state.mn.us>
Cc: <mapserver-dev at lists.gis.umn.edu>
Sent: Tuesday, July 27, 2004 6:48 AM
Subject: Re: [Mapserver-dev] 4.2.2 Release
> Steve Lime wrote:
> > I backported my changes to the templating code, and Howard did so as
> > well with some SDE code. It folks could test things on a few platforms
> > (I've tried MacOS and Linux/Redhat) we should be ready (after Sean's
> > tests) to move forward and release. Thoughts?
> Steve,
> I have run the msautotest suite and only four tests failed. Investigation
> showed those were all expected results from fixes in the 4.2 series or
> acceptable variations. So as far as I am concerned 4.2.2 is ready to go.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
> Mapserver-dev mailing list
> Mapserver-dev at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
