[Mapserver-dev] Is there an issue in the tracker regarding new
work on msImageCreate?
Yewondwossen Assefa
assefa at dmsolutions.ca
Wed Jul 28 18:28:11 EDT 2004
I added an additional argument map object. This function was meant to be
a generic function to create an imageobject based on the format, but it
was only doing it for GD and RAWDATA. I added the other types of formats
that exist (IMAGEMAP, SWF, PDF), but needed a map object to do that.
Thus the addtion of the new argument.
Is this info enough to upgrade the SWIG mapscript ?
Later
Sean Gillies wrote:
> I'd like to discuss what's going on and learn what the
> scope of the work is.
> The change breaks a lot of stuff in the SWIG mapscript.
> Sean
> Sean Gillies
> sgillies at frii dot com
> http://users.frii.com/sgillies
> Mapserver-dev mailing list
> Mapserver-dev at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
