[Mapserver-dev] Is there an issue in the tracker regarding new work on msImageCreate?
Sean Gillies sgillies at frii.com
Wed Jul 28 18:39:07 EDT 2004
Thanks for the reply!
Could you make changes to msImageCreate() so that it's safe to pass in
a NULL map?  That's all I need to make it work.
Sean
On Jul 28, 2004, at 4:28 PM, Yewondwossen Assefa wrote:
> I added an additional argument map object. This function was meant to
> be a generic function to create an imageobject based on the format,
> but it was only doing it for GD and RAWDATA. I added the other types
> of formats that exist (IMAGEMAP, SWF, PDF), but needed a map object to
> do that. Thus the addtion of the new argument.
> Is this info enough to upgrade the SWIG mapscript ?
> Later
> Sean Gillies wrote:
>> I'd like to discuss what's going on and learn what the
>> scope of the work is.
>> The change breaks a lot of stuff in the SWIG mapscript.
>> Sean
>> Sean Gillies
>> sgillies at frii dot com
>> http://users.frii.com/sgillies
>> Mapserver-dev mailing list
>> Mapserver-dev at lists.gis.umn.edu
>> http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
> Assefa Yewondwossen
> Software Analyst
> Email: assefa at dmsolutions.ca
> http://www.dmsolutions.ca/
> Phone: (613) 565-5056 (ext 14)
> Fax:   (613) 565-0925
