[Mapserver-dev] Is there an issue in the tracker regarding new
work on msImageCreate?
Daniel Morissette
dmorissette at dmsolutions.ca
Thu Jul 29 05:42:11 EDT 2004
I guess I'll use this thread as an excuse to remind *all* developers
that we are trying to make use of bugzilla to track *all* changes to the
code, the reasons behind the change, and any related discussions, etc.
That includes small changes like this one. Then when you commit to CVS
you refer to the bug number in your change comment, and if later on
something breaks it is easier to track down why things were changed, and
to make a fix that will remain compatible with the original intentions.
That also makes all our lives easier in updating the HISTORY.TXT since
we can just refer to the bug number instead of writing a long
explanation about a change.
Anyone whose code may be affected by a given change should also be CC'd
on the bug.
This may seem like unnecessary overhead, but as the number of people
with CVS commit access increases, that's the only way to make sure we
keep track of changes.
Actually, I also wanted proposed before that all bug email notifications
go to a mailing list or an alias somewhere, but we didn't get consensus
on that one.
Daniel
Yewondwossen Assefa wrote:
> I added an additional argument map object. This function was meant to be
> a generic function to create an imageobject based on the format, but it
> was only doing it for GD and RAWDATA. I added the other types of formats
> that exist (IMAGEMAP, SWF, PDF), but needed a map object to do that.
> Thus the addtion of the new argument.
> Is this info enough to upgrade the SWIG mapscript ?
> Later
> Sean Gillies wrote:
>> I'd like to discuss what's going on and learn what the
>> scope of the work is.
>> The change breaks a lot of stuff in the SWIG mapscript.
>> Sean
>> Sean Gillies
>> sgillies at frii dot com
>> http://users.frii.com/sgillies
>> Mapserver-dev mailing list
>> Mapserver-dev at lists.gis.umn.edu
>> http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
