[Mapserver-dev] Re: v4.3 and mapogr.cpp
Frank Warmerdam
warmerdam at pobox.com
Tue Jun 1 14:56:44 EDT 2004
Brent Fraser wrote:
> Frank,
> I downloaded the nightly snapshot on Monday and attemped to build
> Mapserver without OGR. I disabled OGR in nmake.opt (for Mapserver and
> GDAL), but mapogr.cpp (line 136) is doing a
> # include "ogr_spatialref.h"
> if USE_OGR or USE_GDAL is set (I'm using GDAL but not OGR at this
> stage). I tweeked nmake.opt to add the ogr directory (line 395):
> GDAL_INC = -I$(GDAL_DIR)/gcore -I$(GDAL_DIR)/alg -I$(GDAL_DIR)/port
> -I$(GDAL_DIR)/ogr
> but I'm not sure this is the "correct" fix.
> Thought you should know...
Brent,
This is indeed the correct fix. I have committed the nmake.opt change to CVS.
The GDAL driver uses the same spatialreference stuff as the OGR side and it comes
from the ogr directory.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
