[Mapserver-dev] [PATCH] mapraster.c - fixing memory leaks
Mladen Turk
mturk at apache.org
Wed Jun 2 12:18:59 EDT 2004
This is a multi-part message in MIME format.
------=_NextPart_000_005F_01C448CE.0325AC80
Content-Type: multipart/mixed;
boundary="----=_NextPart_001_0060_01C448CE.0325AC80"
------=_NextPart_001_0060_01C448CE.0325AC80
Content-Type: text/plain;
charset="us-ascii"
Content-Transfer-Encoding: 7bit
Hi all,
Mapraster has a memory leak bug not freeing allocated temporary layer.
The quickest solution would be to just add the tlptemp variable, but I've
added standard 'cleanup:' label for function exiting.
Having something like mpatrol gives:
Total unfreed bytes: 92899
Peak memory usage: 1699139
Largest allocation: 235750
Smallest allocation: 1
Total Allocations: 513
Total Frees: 505
Peak Allocations: 385
The patch for mapraster.c gives:
Total unfreed bytes: 14
Total Frees: 512
So we've save cca 92K of memory on each request.
Here is the patch:
(I can file a bug report if needed)
There is still 14 bytes left hanging but the reason is in the getString()
from mapfile.c used somewhere :). I'll try to hunt that down.
MT.
name="mapraster.patch.txt"
Content-Transfer-Encoding: quoted-printable
Content-Disposition: attachment;
filename="mapraster.patch.txt"
Index: mapraster.c=0A=
=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=
=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=0A=
RCS file: /data2/cvsroot/mapserver/mapraster.c,v=0A=
retrieving revision 1.117=0A=
diff -u -r1.117 mapraster.c=0A=
--- mapraster.c 1 Jun 2004 14:33:43 -0000 1.117=0A=
+++ mapraster.c 2 Jun 2004 16:05:19 -0000=0A=
@@ -1201,6 +1201,7 @@=0A=
char *filename=3DNULL, tilename[MS_MAXPATHLEN];=0A=
=0A=
layerObj *tlp=3DNULL; // pointer to the tile layer either real or =
temporary=0A=
+ int tlptemp =3D 0;=0A=
int tileitemindex=3D-1, tilelayerindex=3D-1;=0A=
shapeObj tshp;=0A=
=0A=
@@ -1283,6 +1284,7 @@=0A=
msSetError(MS_MEMERR, "Error allocating temporary layerObj.", =
"msDrawRasterLayerLow()");=0A=
return(MS_FAILURE);=0A=
}=0A=
+ tlptemp =3D 1;=0A=
initLayer(tlp, map);=0A=
=0A=
// set a few parameters for a very basic shapefile-based layer=0A=
@@ -1293,12 +1295,12 @@=0A=
tlp =3D &(layer->map->layers[tilelayerindex]);=0A=
=0A=
status =3D msLayerOpen(tlp);=0A=
- if(status !=3D MS_SUCCESS) return(MS_FAILURE);=0A=
+ if(status !=3D MS_SUCCESS) goto cleanup;=0A=
=0A=
// build item list (no annotation) since we may have to classify =
the shape, plus we want the tileitem=0A=
status =3D msLayerWhichItems(tlp, MS_TRUE, MS_FALSE, =
layer->tileitem);=0A=
- =0A=
+=0A=
// get the tileitem index=0A=
for(i=3D0; i<tlp->numitems; i++) {=0A=
if(strcasecmp(tlp->items[i], layer->tileitem) =3D=3D 0) {=0A=
@@ -1308,7 +1310,7 @@=0A=
}=0A=
if(i =3D=3D tlp->numitems) { // didn't find it=0A=
msSetError(MS_MEMERR, "Could not find attribute %s in =
tileindex.", "msDrawRasterLayerLow()", layer->tileitem);=0A=
- return(MS_FAILURE);=0A=
}=0A=
=0A=
searchrect =3D map->extent;=0A=
@@ -1317,14 +1319,14 @@=0A=
if((map->projection.numargs > 0) && (layer->projection.numargs > =
0)) msProjectRect(&map->projection, &layer->projection, &searchrect);=0A=
#endif=0A=
status =3D msLayerWhichShapes(tlp, searchrect);=0A=
- if(status !=3D MS_SUCCESS) return(MS_FAILURE); // TODO: probably =
need more clean up here=0A=
}=0A=
=0A=
done =3D MS_FALSE;=0A=
while(done !=3D MS_TRUE) { =0A=
if(layer->tileindex) {=0A=
status =3D msLayerNextShape(tlp, &tshp);=0A=
- if(status =3D=3D MS_FAILURE) return(MS_FAILURE);=0A=
if(status =3D=3D MS_DONE) break; // no more tiles/images=0A=
=0A=
if(layer->data =3D=3D NULL) // assume whole filename is in =
attribute field=0A=
@@ -1355,7 +1357,7 @@=0A=
if((memcmp(dd,"II*\0",4)=3D=3D0 || memcmp(dd,"MM\0*",4)=3D=3D0) && =
!force_gdal) {=0A=
status =3D drawTIFF(map, layer, img, filename);=0A=
if(status =3D=3D -1) {=0A=
+ goto cleanup;=0A=
}=0A=
continue;=0A=
}=0A=
@@ -1363,7 +1365,7 @@=0A=
if(memcmp(dd,"GIF8",4)=3D=3D0 && !force_gdal ) {=0A=
status =3D drawGIF(map, layer, img, filename);=0A=
+ goto cleanup;=0A=
}=0A=
continue;=0A=
}=0A=
@@ -1371,7 +1373,7 @@=0A=
if(memcmp(dd,PNGsig,8)=3D=3D0 && !force_gdal) {=0A=
status =3D drawPNG(map, layer, img, filename);=0A=
+ goto cleanup;=0A=
}=0A=
continue;=0A=
}=0A=
@@ -1379,7 +1381,7 @@=0A=
if(memcmp(dd,JPEGsig,3)=3D=3D0 && !force_gdal) {=0A=
status =3D drawJPEG(map, layer, img, filename);=0A=
+ goto cleanup;=0A=
}=0A=
continue;=0A=
}=0A=
@@ -1422,7 +1424,8 @@=0A=
szLongMsg);=0A=
=0A=
msReleaseLock( TLOCK_GDAL );=0A=
+ status =3D MS_FAILURE;=0A=
+ goto cleanup;=0A=
}=0A=
}=0A=
}=0A=
@@ -1461,7 +1464,8 @@=0A=
{=0A=
GDALClose( hDS );=0A=
- return MS_FAILURE;=0A=
+ goto cleanup;=0A=
}=0A=
=0A=
@@ -1485,7 +1489,8 @@=0A=
if( layer->debug || map->debug )=0A=
msDebug( "Unable to open file %s for layer %s ... fatal =
error.\n", filename, layer->name );=0A=
=0A=
+ goto cleanup;=0A=
#else=0A=
msDebug( "Unable to open file %s for layer %s ... ignoring =
this missing data.\n", filename, layer->name );=0A=
@@ -1501,20 +1506,21 @@=0A=
if(status !=3D 0) {=0A=
if (status =3D=3D -2) msSetError(MS_IMGERR, "Error reading EPPL =
file; probably corrupt.", "msDrawEPP()");=0A=
if (status =3D=3D -1) msSetError(MS_IMGERR, "Unrecognized or =
unsupported image format", "msDrawRaster()");=0A=
+ goto cleanup;=0A=
}=0A=
continue;=0A=
} // next tile=0A=
=0A=
+cleanup:=0A=
if(layer->tileindex) { // tiling clean-up=0A=
msLayerClose(tlp);=0A=
- if(tileitemindex =3D=3D -1) {=0A=
+ if(tlptemp) {=0A=
freeLayer(tlp);=0A=
free(tlp);=0A=
}=0A=
}=0A=
-=0A=
- return 0;=0A=
+ =0A=
+ return status;=0A=
}=0A=
=0A=
/=0A=
=0A=
------=_NextPart_001_0060_01C448CE.0325AC80--
Content-Type: application/x-pkcs7-signature;
name="smime.p7s"
Content-Transfer-Encoding: base64
filename="smime.p7s"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------=_NextPart_000_005F_01C448CE.0325AC80--
