[Mapserver-dev] Re: [Mapserver-docs] RE: MapServer Documentation Update
kgeurts kgeurts at gis.umn.edu
Fri Jun 4 15:24:10 EDT 2004
Hello Lowell and MapServer Documentation Authors,
With regards to updating the documentation to 4.2, I wanted to give authors
at least a week to update their documents and commit them to the 4.2
branch. I plan to have 4.2 become the main documentation webpage by the end
of next week. I will however, continue to add documents to the 4.2 page as
authors provide the updated versions. Hope this helps.
Thanks,
Kari A. Geurts
MDP Coordinator
Department of Forest Resources
University of Minnesota
1530 Cleveland Ave N.
St. Paul, MN. 55108
Phone: 612-624-3459
Fax: 612-625-5212
On 4 Jun 2004, Lowell Filak wrote:
> Obviously ASAP is the easiest answer, but what is the proposed deadline
> for having 4.2 compatible documentation available by so the main
> documentation page can be updated?
> Thanks.
> Lowell
> The following message was sent by kgeurts <kgeurts at gis.umn.edu> on Tue,
> 01 Jun 2004 15:41:11 CDT.
> > Hello MapServer Documentation Authors,
> > The release of the MapServer version 4.2 code has occurred! With this
> > release comes the need to update the MapServer documentation. We are
> hoping
> > you can take the time to review your document and make the necessary
> > changes so it is compatible with the version 4.2 code. We are asking
each
> > author to do the following:
> >  - Make any necessary changes to your document to ensure it is
compatible
> > with
> >    the 4.2 code.
> >  - Include the version number 4.2 in the title of the document.
> >  - Add a history revision section to your document.
> >  - Commit the document to the 4.2 CVS branch.
> > The 4.2 branch has been created for the mapserver_docs tree. The branch
is
> > called "branch-4-2", so you can commit or checkout a new set of 4.2
files
> > using:
> >    cvs -d :pserver:...... checkout -r branch-4-2 mapserver_docs
> > or you could do the following on an existing CVS tree to update it to
4.2:
> >    cvs update -r branch-4-2
> > After authors have made the changes above and documents have been
> committed
> > to the 4.2 branch the MDP website and automatic update script will be
> > changed. Only documents that have been stated by the author to be
> > compatible with version 4.2 will be put on the main MDP webpage. There
> will
> > be a link to old versions from the main page.
> > The automatic update script will then be for the 4.2 stable version
> and the
> > main branch will be the development version. If you make changes to
your
> > 4.0 or older documents you will need to contact me so I can update
these
> > manually.
> > Thanks very much for your attention to this.
> > Kari A. Geurts
> > MDP Coordinator
> > St. Paul, MN. 55108
> > Phone: 612-624-3459
> > Fax: 612-625-5212
> > Mapserver-docs mailing list
> > Mapserver-docs at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-docs
