[Mapserver-dev] [PATCH] mapraster.c - fixing memory leaks
Steve Lime steve.lime at dnr.state.mn.us
Tue Jun 15 19:03:16 EDT 2004
Patch aside, what do folks think about using goto's? They seem a great
help with things like clean-up. However there's not one in the code
presently so I was wondering if there's a bias...
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> "Mladen Turk" <mturk at apache.org> 06/02/04 11:18 AM >>>
Hi all,
Mapraster has a memory leak bug not freeing allocated temporary layer.
The quickest solution would be to just add the tlptemp variable, but
I've
added standard 'cleanup:' label for function exiting.
Having something like mpatrol gives:
                Total unfreed bytes:        92899
                Peak memory usage:        1699139
                Largest allocation:        235750
                Smallest allocation:            1
                Total Allocations:            513
                Total Frees:                  505
                Peak Allocations:             385
The patch for mapraster.c gives:
                Total unfreed bytes:           14
                Total Frees:                  512
So we've save cca 92K of memory on each request.
Here is the patch:
(I can file a bug report if needed)
There is still 14 bytes left hanging but the reason is in the
getString()
from mapfile.c used somewhere :). I'll try to hunt that down.
MT.
