[Mapserver-dev] Any experience with SQL Relay?
Zamil Murji
Zamil.Murji at divestco.com
Fri Jun 18 12:44:28 EDT 2004
Hi Sean,
Before you go to far with SQL Relay, here is an interesting note that I came across in the FAQs.
Does SQL Relay support XXX's specific features?
Database Queries Bind Variables Procedural Language Auto-Commit
PostgreSQL Yes Scalar Input No No
Now I'm no PostGIS guru but I'm pretty sure that it makes heavy use of plpgsql (procedural language for Postgres).
If that is the case, then SQL relay would be out of the question because it does not support Procedural Language for postgres.
I hope that kind of makes sense. Here is the link to their FAQ:
http://sqlrelay.sourceforge.net/sqlrelay/faq.html#features
Zamil
-----Original Message-----
[mailto:mapserver-dev-admin at lists.gis.umn.edu]On Behalf Of Frank
Warmerdam
Sent: Friday, June 18, 2004 10:21 AM
To: Sean Gillies
Cc: MapServer-Dev
Subject: Re: [Mapserver-dev] Any experience with SQL Relay?
Sean Gillies wrote:
> I'm looking into whether SQL Relay
> would be useful for improving MapServer connections to PostGIS.
> Anyone have any experience with this software? Any reason
> why I couldn't implement a PostGIS driver that would connect
> to an external SQL Relay connection pool?
Sean,
My understanding is that the connection cost for PostGIS is negligable.
However, it might be of great interest to do this for Oracle and ODBC
connections.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
Mapserver-dev mailing list
Mapserver-dev at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
