[Mapserver-dev] Any experience with SQL Relay?
Sean Gillies sgillies at frii.com
Fri Jun 18 12:52:57 EDT 2004
On Jun 18, 2004, at 10:44 AM, Zamil Murji wrote:
> Hi Sean,
> Before you go to far with SQL Relay, here is an interesting note that
> I came across in the FAQs.
> Does SQL Relay support XXX's specific features?
> Database   Queries Bind Variables Procedural Language Auto-Commit
> PostgreSQL Yes     Scalar Input   No                  No
> Now I'm no PostGIS guru but I'm pretty sure that it makes heavy use of
> plpgsql (procedural language for Postgres).
> If that is the case, then SQL relay would be out of the question
> because it does not support Procedural Language for postgres.
> I hope that kind of makes sense. Here is the link to their FAQ:
> http://sqlrelay.sourceforge.net/sqlrelay/faq.html#features
> Zamil
Zamil,
Thanks!  I missed that first time through.
Sean
